i=p/u
Supporter
Dec 9, 2010
7,461
817
1,688
Northern Ireland
United Kingdom
Will a cheap bagless Hoover work with a wall chaser??? Goes and against s please...
Yes it will. For a few minutes!
Best to look at a good industrial vacuum!
Reactions: 1 person
I have a Hilti hoover. It can cope with dust but a cheap domestic hoover most certainly could not!
I've about 20-30m of chasing todo
Would a Henry cope with few hours chasing
Most bagless cleaners have soppy little filter that will fill with plaster dust in 2 minutes, you would spend all your time cleaning it. Henry will be fine, just a lot of emptying compared to a full size canister machine.
Reactions: 1 person
i`m using a henry in bagless mode. there is a good filter, needs cleaning every couple of chases but otherwise it works well.
used for a lot of chasing and site cleaning, is still going well (except for on-off switch, killed by dust. i bypassed it and machine still works :-))
Reactions: 1 person
20 - 30 miles of chasing? i wouldn't chase a woman that far.
Reactions: 4 people
Reactions: 1 person
I use a Stihl hoover. The use a bag but they also have a replaceable filter for when you use them without. Works very well
Reactions: 1 person
Reactions: 2 people
and as for vacuums, for a group of electricians that are supposedly hot on correct terminology. a henry/hilti/nilfisk vacuum is not a bloody hoover. a hoover says hoover on it. same as a fluke is not a megger.
Reactions: 4 people
In that case you better stop using the words aspirin, cellophane, cat's eye, escalator, lino, sellotape, thermos, jet ski, bubble wrap, jacuzzi, breathalyser, chapstick, bikini, heroin and trampoline unless you are referring to specific products that hold the trademark name. ;)
Reactions: 4 people
On the generic "hoover" front...the Henry range are good yokes,for the money. Nilfisk,Stihl,Hilti,and a few others are excellent machines,but it is as well to remember that the machine with the best filtration,will catch the most dust,and block quicker.
If you have a model that can be used "bagless",the main filter will bare the brunt of it,and on the premier machines,these are not cheap,or easily cleaned.
A tip for extending the life of these,is to cut the top off the new bag,you would have used anyway,and wrap it round the main filter.
As an aside,i have several of the better models,but the Steyr i purchased twenty years ago,refuses to die,and is in frequent use,including ingesting the internal detritus contained in my folks multi-fuel boiler stove,which has been the death of many a vacuum...
A Henry will do the job, but I found the bags would clog up too quickly. I use a Nilfisk multi 20, a great machine. The wall chaser plugs into the Nilfisk, when you turn on the wall chaser the nilfisk multi 20 automatically turns itself on. Also the bags last for ages before they need changing. A cracking piece of kit.
Interestingly before I purchased the nilfisk, I bought a dusk extractor from screwfix (see link below) and when I read the instructions it said 'not to be used for dust'. Work that one out- needless to say it got returned.
What a waste of time and im sure there is some trade descriptions act in there somewhere
http://www.screwfix.com/p/woodstar-dc04-54-3ltr-sec-dust-extractor-230v/61772
check out page 11 of the instruction manual
Reactions: 1 person
I've got a nilfisk with the auto switch on but I'm not sure which model it is now. It's a great bit of kit.
Can't open that link on the phone but it will be a chip collector for attaching to a big bench planer or spindle moulder they are no good for fine dust which is probably what it means
Reactions: 1 person
I've got one of these too, nilfisk alto aero, just use a decent bag and change fairly regularly, doesn't cost much.
Reactions: 1 person
Got mine on recommendation off someone on here so thanks whoever it was! Use it with an erbauer chasing machine which does me for about once monthly use quite nicely.
It doesn't matter what the badge on the front says, the Scousers will nick it anyway. :laugh:
what's up? someone nailed down your coffin lid befoer you got back in? :smilielol5::smilielol5::smilielol5:
Reactions: 2 people
we're getting selective now. never nick a dyson, it's probably broke anyway.
Reactions: 2 people
Cheap and vacuums is maybe possible. But I would say cheap and dust extraction (to HSE standards) do not go together. see:-
http://www.hse.gov.uk/pubns/cis36.pdf
If you don't do this kind of thing often and don't have the right dust extrator then I would suggest using hire tools and price the job accordingly.
My dust extractor was not cheap.
Reactions: 1 person
Salt and vinegar
...This must be what causes the nights to draw in...
As for Screwfix and their "flexible fit-for-purpose" policy...a mate bought some diamond hole drills,and on testing them,they were found to be chips of nougat,held in place with gingerbread...right turn,Clyde...:conehead:
Reactions: 2 people
Any wonder I deink, Fix a fooling drink d day pal
http://www.screwfix.com/p/woodstar-d...tor-230v/61772
.:conehead:
:biggrin::biggrin:
what make/model do you have? As you don't mention it.
Probably Bosch Hoover about 300 plus chaser??
I've tried 2 Henry hovers for chasing, both didn't last long. Got a nilfisk and it's 1000 times better
If using it with a chaser I wouldn't use anything less than an m class dust extractor. I have a Bosch gas35 M class. Wouldn't be without it!
My chaser packed up and as we have a few rewires on rushed out and bought a makita chaser and extractor last week on recommendation from the local tool shop(it was in stock) it's goin back tommorow the extractor is utter sh!te and one of the lads reported a near miss as the on/off switch on the chaser is diffulct to turn off. I tried the chaser on Friday apart from the on/off switch not being great it was fine when connected to the festool extractor but awfully messy when connected to the makita it was bought with
I ruined an L class metabo in a day chasing. The m class ones are a lot of money but they will handle the dust much better. I have just got some dust bags with a zip at the bottom too so really easy to empty and reuse.
i=p/u
Supporter
Northern Ireland
United Kingdom
Hoover for wall chasing
i=p/u,
DPG,
