A
aaronstuart
This installation was done a couple of years ago, with a dedicated 20 amp supply, and ran in armoured.
Its a PME supply.
No earth to water which will be sorted asap.
He has informed me that on 2 occasions he has had a nasty shock while testing the temperature of the water, as he was standing on the ground. ( the tub is outside ).
I couldn't see anything wrong with the circuit wiring visually, but i was unable to test it.
When he phoned up the manufactures, they said it could be a bad earth connection resulting in feedback? Could this be caused by there being no earth on the incoming water pipe?
Any advice would be much appreciated on how to deal wtih this.
Obviously i told him not to use it.
Many thanks
