Is there an indicator lamp associated with the thermostat? Most ovens have a red light tht goes on or off, depending on whether the elements are being fed power or not.
If the red light is cycling on and off, and it doesn't reach the desired temperature, then it's probably the 'stat at fault
If the red light stays on continuously, and it still doesn't get up to temperature, then it could be one of a parallel connected pair of elements has failed..
Norton
Hotpoint oven fault
Electrical Appliances & Whitegoods Forum
Thread Tags
Tags Tags
fault oven
Paul Lathan,
brianmoooore,
