Discuss How to avoid overloading your inverter? in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
Porkstone
I have an 11kw inverter installed at home. If I turned on enough appliances it would be possible overload the inverter. Is there a way to detect this and avoid it?
This particular inverter is off-grid, so it doesn't back feed to the grid.
It does have a mains pass thru mode, but if I understand correctly it will not handle more than 11kw in pass thru mode. (I could be wrong about this, hopefully I am)
In my original post I probably should have explained that it is an inverter/charger connected to a battery bank, a solar array and the mains.
This is the unit
reading the instructions has lead me to believe that the unit can only provide 11kw and i think it includes the pass through current that would be irrelevant anyway as you say it is off grid so no power is available to pass through anyway??
there is one relay output but it seems to be pre configured as a battery low warning and the instructions do not say that it can be reprogramed to say the device is overloaded.
it looks like the unit will provide up to 22kw for 2 seconds to cope with spikes in demand.
Reply to How to avoid overloading your inverter? in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hello everyone. I have a inverter configuration problem I thought someone here might be able to help with. I'm not looking for a specific solution...
