Hello,
Went out to visit a house last night and the owner admitted that the best description for her electrics was "Interesting"
Anyways a local spark has been up there a lot, and admittedly rewired almost the entire property except this one room, a treatment room of sorts. She through a friend and her son who I know well have said slightest thing goes e.g. a lamp and all the electricity goes out, and so she wanders around with a little kind of sticky backed LED torch affair on her pocket ! as when it goes it's upstairs and downstairs ring finals, lights all through and lots more. She seems to have power through to treatment room via a few 4 -6 way extension leads and referencing one Belkin one she told me that the electrician who was originally doing loads of works said it's ok because it's specifically for computers ! ( it is Belkin ) but nothing more than really anti-surge extension lead. So there are I think 3 or 4 large computers, quite old ones estimated and so I'm thinking has CU got RCD's i.e. combined leakage currents ? Then she says she lost it at electrician who tripped power one day as treatments going on and clients panicked as all went dark ! I think he just tripped a protective device. I find local CU and all just hager mcb's and no rcd's etc..
Then I ask her son and he says oh yes another board up there pointing at a back room / alley inside. There is a 3 phase Hager D/B with various circuits and running a feed down from there to other sub CU I originally found which only has a type B 50A RCBO protecting it single pole @ 30mA trip ! Now starts to make sense with the computers in what she says is an old damp room, kitchen ring, washing machines, fridge all fed from the RCBO to the other CU ! So thats I'm guessing why the computers won't stay running from the treatment room but do from extension leads in a different ring / part of property.
So this is the more fun bit ! She says the Original electrician turned up with a black box held out in front of him at arms length and wandered around the treatment room saying "you want around 100 and normally no lower than 40, and you're at 10 in here and when you get down to 3 you're really going to have to get it re-wired in here " ?? I have no idea what the heck this black box is / could be or what he was measuring other than paranormal ectoplasm or such. I did ask her if he was checking the Wi-Fi signal as that would've made more sense on db loss but no she said to do with the sockets not working in there for computers ! She also mentioned the re-wiring of the sockets that 2 x others apparently diy'ers had said they could do as she won't have floors up or walls chased in there.. Don't think it's the wiring, I'm thinking the original 30mA RCBO is bad design feeding the entire CU down there with no discrimination or arrangement of final circuits.
She's a bit far out but lovely and a white witch, crystals, tarot readings, and so I'm informed high priestess of paganism and occult stuff so I've got to be on my best behaviour.
Thing is previous spark is very good and has run some big jobs over here.
