chgodon
IL
United States of America
Business Name
Personal
During the recent 2 day power outage in Northern Illinois, I purchased a portable generator. 8,125 starting watts and 6,500 running watts. I plugged my 2015 LG fridge in one 120v 20 amp receptacle with no problem. I plugged my 2002 Maytag fridge in the separate120v 20 amp receptacle. After that, the Maytag kept tripping the receptacles, even the wall one it was plugged into for years. My appliance tech said fridges should not be plugged into generators due to voltage fluctuations and dirty power. What the heck, it's an emergency. He replaced some type of cooling timer which fixed the fridge issue.
I was thinking of hooking my generator to the breaker box via an inlet box next time. Then use an interlock kit on the breaker box. My question is would this be safer for the fridge instead of going directly into the generator? Do breaker boxes act as rectifier/inverter for stable voltage and cleaner power?
I have a Sigenergy system (called Pointguard in the states), it is a DC battery back up system that operates on mains and has an interlock to isolate from the supply and run the property- this uses the gateway which is an automatic changeover switch
The system has a 'smart port' feature that allows it to take a dirty generator input, clean it up, convert it to DC and it then uses the DC to power the property using the built in inverter
It also can operate a generator automatically and start it up when the system drops below a pre set state of charge
The system also has MC4 connectors to take direct solar- this would give you battery, generator, off grid and solar in one unit
IL
Business Name
Personal
Portable Generator & Refrigerator help!!
DIY Electrical Advice
Thread Tags
Tags Tags
generator
chgodon,
baldelectrician,
