Search the forum,
Discuss Rcds in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
the RCDs are wired in series, as the load current passes through RCD1 then RCD2. either one trips, the current is Zero. if they were in parallel, 1 RCD trips and the other one would pass the load current. here endeth the lesson. :p:rolleyes:o_O
Reply to Rcds in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
