Discuss Should i do 2392 or 2391 testing and inspection? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
swaRRR
So i've been doing electrics for several years now, and am going for my 18th edition this week. I'm 99% confident i'm going to pass it.
After that i want to do a proper testing and inspection qualification. I've never done much testing but need to learn it for obvious reasons. I have Guidance Note 3 and various resources which i'm just digging into now.
I know i can do the Initial Testing and Inspection 2392 but i'm wondering if there is any point? ie, will it lead to work?
I don't want to pay for the Initial which is gonna be about £800 if i then just have to pay another grand to do Initial and Period in another course to get the 2391.
My only worry is the course being a bit too advanced for me.
I have access to testing equipment and can set up a rig, along with doing more stuff at work, but i don't want to go straight for the exam if there's a good chance i'll fail it.
So, is the 2392 worth it to get me going (for more job opportunities) or is it just worth waiting and going for the 2391 when i'm ready?
It is difficult to advise I would say go for the 2391 but then I don't know your level of qualification, competance or experience
If testing and inspection is a regular part of your work and you have a good knowledge of test equipment then you should not have a problem
When it comes to the exams try and stay calm no matter how much the clock is wanting you to stress out
2392 covers Initial verification only and is Level 2
2391 also covers Periodoc Inspection and is level 3
2391 is generally considered a requirement to perform EICR's as it demonstrates a level of knowledge, although technically it's not actually required, some customers, businesses, insurance companies may not accept your certificate without 2391 and/or membership of one of the contractor schemes.. IMHO If you have experience, just go for 2391
Thanks for the responses guys.
The 2392 is the initial verification only, and they say it's for those inexperienced with testing.
Really, how much more difficult is the periodic inspection? So much more difficult they apparently had to separate the two so people could pass.
Is this the reality of it? How much harder is periodic inspection than initial verification?
It all comes down to experience and how much you have of it to be fair.
If you’ve got very little experience in testing and filling out the associated paperwork, I’d probably hold back on doing it for a bit until you’ve got more, especially 3 phase installations as they’re a big part of the assessment.
It’s the practical where most people fall down as they run out of time, don’t leave enough time to complete paperwork, fail on safety etc…
The periodic testing & inspection includes (or at least it did some 10 years ago) faults you have to find and a set of photos of issues that you have to correctly identify & correctly code. Which needs some experience of what to look for.
I've been googling on this for a while now - as I understand it you need 18th, 2391 and NVQ to get ECS Gold Card (having already achieved installation level 3 quali).
I too have several years experience on the tools but limited knowledge of testing. I'm on the brink of taking the plunge and signing up with XS Training to do their online 2391 course, with a view to going on to 2346 NVQ after that.
I understand 2391 isn't easy, but I'm confident that if I put the hours in I can do it. If not, at least I tried, gained some knowledge, and only lost £900, which isn't huge in the grand scheme of things.
The 2392 is like 700 quid too on its own. I've been told by several installation managers i know that they don't really recognise the partial qual and want the 2391 so i'm gonna wait and go for that.
Yes, seems to me the 2392 is just like a soft version of 2391 that you can do as preparation. On its own it doesn't hold much value.
You could break it up into 2391-50 Initial Verification then do 2391-51 Periodic later. But that's more work and more expense for the same result, so most people do 2391-52 combined course.
I'll let you know how I get on with it.
Potentially quite a bit. Any faults found during IV can generally be pinpointed quickly and with certainty, after all you'll know the exact cable runs, have a fairly good idea on external influences that could've caused your issue and thr like, however with EICRs youre effectively starting from scratch, with no idea on cable routes, installation methods, customer have-a-go handiwork and the like. You'll also likely see a snake orgy more often than not whereas with IV you're (hipefully) making the installation easier to navigate and neater.
While the 2 do share a lot of fundamentals in terms of testing, thry are drastically different from one another. One is verifying against a design (and if we're not then why not?) the other is ascertaining if the installation is fit for continued service (and checking against a design if possible)
2392 if I remember rightly teaches testing where 2391-50 is Periodic Inspection with some experience
Please do mate it'd be an eye opener for me.
Makes sense, thanks.
Do you have your 2391? If so how did you find it?
you'd be surprised how many go on the 2391 with no tester and/or zero experience
Which probably accounts for the high failure rate.
I think there was 9 on my course, and only 2 of us passed first time around.
I would say it beggars belief but then the 2392 suffers from Short Course tarring (DI courses anyone?) and as such isn't that well received compared to the 2391 that almost everyone knows.
The main differences between the 2392 & 2391 is the 2392 is single phase only which is level 2 & the course itself you will be taught practical on how how to test. (This qualification is no longer recognised)
Where as the 2391 whether that's the 2391-50 or 2391-51 or combined 2391-52 is single phase & 3ph level 3 for experienced electricians where if you don't know how to test you're on your own & will likely fail as no practical training will be given.
If there's no practical training then what's the point in the 'course'? Waht DO they teach on them?
As stated above, it’s for experienced electricians that know how to test, and do it day in, day out.
It’s very heavy on theory and GN3, you’re expected to know how to test and interpret those results prior to going on the course.
I’ll be honest, if you’ve got limited testing experience (especially 3P&N), you’re probably going struggle.
Build yourself a test rig, get to know your MFT, watch some sparky ninja videos, and practice practice practice until it becomes second nature.
Reply to Should i do 2392 or 2391 testing and inspection? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi Guys, looking at doing Initial and Periodic inspecting and testing. Looking between the CandG and EAL Just wondering if I can ask peoples...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi all, I am currently doing my 2391-52 testing course, can anyone recommend where I can find revision past paper or online revision sites for the...
Hi, has anyone completed the CG 2391-52 inspection & testing course online with LearnZone Media recently? Just looking for opinions or feedback...
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
