Discuss Single Phase AC MOTOR stuck in the UK Electrical Forum area at ElectriciansForums.net
I am trying to fix a single phase ac motor but need some help. When powered on and put off load, motor humms but doesnt rotate, its sort of magnetically locked because even trying to rotate by hand it very hard to turn (motor was removed from housing and therefore I have stator and rotor exposed)
When switched off, rotor turns freely and smoothly by hand, therefore bearings are not an issue.
Motor is a capacitor run. Checked capacitor and both windings, all looks fine (see image attached). Coils ohmage measured was 15 and 40 ohms and capacitor reads 10microF OK.
Can someone please help what could be the problem? Thanks!
Hi
Did you solve the issue, how
I have the same issue in motor
Centrifugal switch gone U/S
Reply to Single Phase AC MOTOR stuck in the UK Electrical Forum area at ElectriciansForums.net
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
hello!! hope anybody can help me. I have an AC single phase 220v 1.5HP motor that won't rotate when plugged in even when I try to do it by hand...
Hi Forum Members I have a 4 pole single phase 240VAC 315 watt motor from a central heating heating system that I think is bad. It's the room fan...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
