- Reaction score
- 17,092
Thanks Mate, needed to ask, seen some stupid stiff in my time, not in any way that what you have done is stupid,I am trying to run it fixed as it should be: with both rotor ends inserted into both bearings.
Discuss Single Phase AC MOTOR stuck in the UK Electrical Forum area at ElectriciansForums.net
I am trying to fix a single phase ac motor but need some help. When powered on and put off load, motor humms but doesnt rotate, its sort of magnetically locked because even trying to rotate by hand it very hard to turn (motor was removed from housing and therefore I have stator and rotor exposed)
When switched off, rotor turns freely and smoothly by hand, therefore bearings are not an issue.
Motor is a capacitor run. Checked capacitor and both windings, all looks fine (see image attached). Coils ohmage measured was 15 and 40 ohms and capacitor reads 10microF OK.
Can someone please help what could be the problem? Thanks!
Centrifugal switch gone U/SI am trying to fix a single phase ac motor but need some help. When powered on and put off load, motor humms but doesnt rotate, its sort of magnetically locked because even trying to rotate by hand it very hard to turn (motor was removed from housing and therefore I have stator and rotor exposed)
Reply to Single Phase AC MOTOR stuck in the UK Electrical Forum area at ElectriciansForums.net
