Dec 24, 2019
458
1,473
1,168
Bucks
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
What I can't seem to get any information on is, 'does increasing the heat cause more electricity, if so what are the temperature ratings of the chromel & Alumel' wires?
Yes Increasing the temperature increases the thermoelectric junction voltage, however it is in the mV range. (0.2-1mV/K)
It is basically how thermocouples work, they are very reliable, and accurate for temperature measurement.
Not very efficient in generating voltage, and small current though.
  • Informative
Reactions: pc1966 and OnlQQker
Thanks Julie,
It was whilst I was studying thermocouples that has guided me down this path.
I have this hairbrained idea about using heat produced by compost, but I've got to research the ingredients for the compost which produces a constant heat all year around without having to turn it to often.
All without causing some kind of explosion! 🤔
Thanks Julie,
May be better off capturing the gas and using that....
  • Informative
Reactions: OnlQQker and James
Thermoelectric generators are not very efficient, but have the advantage of no moving parts to theoretically a very long reliable life:
Where they do find a niche use is deep space probes using a radio isotope for heat, not just because you get damn-all sunlight out there, but also the "waste heat" is valuable in keeping stuff that has to be at normal electronic operating temperatures at them when all around is heading towards -270C or so:
  • Informative
Reactions: OnlQQker
Buy a cheap peltier device and experiment with that (this has many PN junctions) , the trouble is keeping one side hot and the other cool .
  • Informative
Reactions: OnlQQker
Thanks for all the replies, searching 'peltier device' above has sent me on a funny old journey of the 'Radio Photovoltaic Generator'
For anybody interested this came up in the top results of YouTube
I might need to grow my hair long like this guy 😂
Easy, just reverse the power flow and one get hot, the other cool :)
Bucks
United Kingdom
The Seebeck Effect....
OnlQQker,
pc1966,
