Losing my mind with my 2008 Audi A6 3.0 TDI
Fault code 3348 for turbo actuator, clear the code, instantly comes back
Turbo and actuator has been swapped for a new recon unit from a specialist, pre-calibrated
Turn ignition on, the inlet manifold actuators self test sweep, but the turbo actuator just doesn't move
I've tried my old actuator, and a 3rd actuator, it still doesn't move (had it confirmed that they don't even need to be calibrated for the self test sweep).
It's on a 20A fuse in the engine bay under the windscreen, this fuse is good and everything else on the circuit works fine
Everything else on the circuit has been unplugged, no change
There's 4 pins on the turbo actuator plug:
Pin 1 - Ground
Pin 2 - Switched 12v live
Pin 3 - Goes to ECU
Pin 4 - Goes to ECU
I've even cut the plug off and have properly crimped a brand new plug end on
I've checked pin 1 and pin 2, 12v fine
I've tested continuity on pins 3 and 4 from both ends and this is absolutely perfect, 001 reading on the multimeter
I've cleaned the pins on the ECU with a dental teepee brush (they were already spotless but worth a shot) and sprayed contact cleaner
When I scan with VCDS the only change I get with the code is if the turbo actuator is plugged in or unplugged. Unplugged I get a duty cycle of 0.4% and plugged in I get 20.5% (I'm guessing this is proving pins 3 and 4 are good which go to the ECU?)
At a loss with it, the only thing I can think is that the ECU may be at fault, but everything else is working fine and I can't find anything online with ECU problems like this
Any clues guys?
Pin 1 - Ground
Pin 3 - Goes to ECU
Pin 4 - Goes to ECU
Any clues guys?
