Discuss Whats wrong with this pic in the UK Electrical Forum area at ElectriciansForums.net
Hi I just start job need help with description whats wrong wit neural
No neutral from bottom of second DP switch to neutral bar. I'm guessing an RCD has been replaced at some point due to nuisance tripping?
old split load board with trippy rcd , so some clever sparks swapped out the rcd for a main switch , seen this loads of times
my guess is that they re-used the old splt board when rewiring and it tripped out so they took the easy option
Having a main switch instead of the RCD is not immediately dangerous or potentially dangerous.
there are issue that can be coded due to inadequate additional protection, but I can’t see the main switch being a Code in itself. What do you think?
Dunno never seen switch with no neutral so Dunno how to code this also rcd sometimes tripping on zs low 3lead test is neutral arrangements can cause that or earthing problem I put as earthing problem
Just ask yourself is this issue immediately dangerous? Is someone in imminent danger?
or is there a potential danger? Could some one come to harm if some one does something?
ask yourself if the double pole isolator without a neutral is dangerous and how is it dangerous? Justify your coding.
I don’t like it, I think it’s wrong. just because I don’t like it and think it’s wrong doesn’t mean I can code it. I can’t just say it’s wrong. you have to give a valid reason why it is electrically wrong.
so what do you think? Does it need coding? And why?
What was the earthing problem?
Q
Reply to Whats wrong with this pic in the UK Electrical Forum area at ElectriciansForums.net
Right or wrong please? , if wrong, what needs to be done to fix it? thanks in advance.
Hi I have inherited a compressor with a single phase motor but its been stripped and I need to fathom out what's what.. I don't know if it even...
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
