- Sep 24, 2013
- 1,519
- 2,493
- 3,688
- United Kingdom
- Business Name
- Dovecote Electrical
Eh up
My dad (retired joiner) has been gifted an old ('40s or '50s) Myford ML8 wood lathe. (Made in the town where I now live).
It comes with what he thinks is (but may not be) the original motor; from the name plate (details read out to me over the phone, haven't seen it): English Electric, single phase a.c., 0.5HP, 1440 rpm, 3.7A full load, 230-250V, frame MS5126, continuous rating, SEE 5244/87.
The spindle speed is controlled between 700 and 2850rpm by stopping the motor, and moving a belt between two sets of 4 V-pulleys (much like a pillar drill). My dad would like to control the speed using a knob or some such.
I have seen this type of lathe fitted with a variable frequency drive (VFD), for example this one on ebay. It looks like the way this is usually done is to replace the single phase motor with a 3 phase equivalent, for which a single phase in/3 phase out VFD can be sourced relatively easily.
I'm aware of the Invertec Optidrive E2 single phase in/single phase out motor control (I'm sure other makes are available), this is only suitable for shaded pole and permanent split capacitor motors (no idea what sort my dad's motor is).
So what are the options? Should I just "get an electrician in," or is this something a trainee can safely do? I'm fine with terminations, and following schematics/instructions, but I've got no experience with motors or VFDs. I'd love to learn, though.
If the former, is there anyone in Norfolk (North Walsham's the nearest town) can help? I'll be going over there 20-30th this month.
Any advice appreciated, even if "leave it to the professionals, lad" (but hopefully not!). My dad's thrilled to be getting this old machine working again, I would dearly love to help him out.
Cheers all
Cheers all
