Looked at that and the cupboards at the top are full length and go right to the ceiling, look custom made so no sneaky void hiding up top by the looks of things sadly!
Well there is some sort of extra wood fastened to the face of those cabinets
I with @Leesparkykent, fish it under the plinths and through the wall. Solid board cutter route will be just as good, there are blanks specifically designed for the cut out. Export the TNCS as its a perfectly expectable method, just make sure if its PME that there isnt any extraneous bonding in the new shed. Make sure there not going to ask for Infrared heaters as your 4mm will struggle.
one find the socket in the utility area extend to outer wall .
fuse spur in side car case
one gav stop end box outer wall swa and extend to new shed job done .
or ring a friend.
  • Informative
Reactions: DavidSpark
Brilliant, thanks very much everyone, lots of food for thought on how to get to done! I'll take a look at getting it under the plinths, I'll hopefully get this done in the "near" future and show you how it went!
Thanks, @Pete999 , @Leesparkykent , @telectrix , @buzzlightyear , @tomspark93 , @LankyWill for your input and experienced advice, very much appreciated!
now, now, murdoch. you don't export it, you just extend it.
  • Funny
As Tomspark mentions - if the 'bar' will only be a small load and it is a pain to route the SWA, then run from a FCU in the house spurred off skt ring. There is a IET Wiring Matters regards this very arrangement - see attached.
Otherwise, unless there specific bonding requirements in the shed i.e. copper water pipe, Jacuzzi; then run a 3C SWA (suggest > 2.5mm^2) - no need for a dedicated rod. (Subject to how far away 'bar' is from house ideally less than 10mtr)
  • Informative
Excellent reading! Thank you for providing it, and your advice.
this site is like Tesco's, every little helps.
Reactions: tomspark93
where is my points post 31
IMO better than spurring from downstairs ring (where applicable). Most home owners want more than just one socket outside eventually so why just give them one when you can have a dedicated radial on its own RCBO. Easier than punching holes in walls through utility rooms too.
At least if you spur from the ring you don't leave the installation without a single main switch!
But in all seriousness I don't particularly condone installing a shed supply from a ring either.
Your solution doesn't show any consideration for discrimination. And this thread isn't about installing a single outdoor socket, it's about a submain to a shed.
Just because something is easier it doesn't mean it is the best installation design.
Glasgow
Power to shed. Thoughts?
DavidSpark,
davesparks,
