E
elsparko
as a 1st/2nd year i was always taught as a rule of thumb that if a tap/wateroutlet can be reached whilst touching the pendant/fitting that it should be upgraded to a waterproof chap.
i C2 3 fittings on friday and its being questioned by landlord, am i right in thinking that any room that has a shower/bath must have waterproof light fittings? the other bathroom is just a bog and a sink so i think that one would be ok but i would still c3 it.
another thing was my equipotential bonding, the boiler is supplied by metal gas pipe (correctly earthed) it is copper piping at the boiler but entering the house it turns to plastic pipes, do i need to cross bond the boiler pipes or are they covered by the gas/water services being earthed and the fact that its plastic pipe into the house?
away to dig out my regs book but thought id chuck a few questions on here
The light fitting must be suitable for the location.
I would think it rare (other than perhaps if its in a special location) in most circumstances that a boiler would need bonding ever
i agree but apparently their second opinion reckons a pendant with metal shades is suitable for location, 2 of the lights are definitely within half a metre of the shower/and bath
it should be bonded inside but on a council contract we were specified that the boilers must be crossbonded, and all hot/cold at sinks, even when they are rcd protected and main services bonded anyways.
I just read up on the regs and the boiler is definitely ok, but the light fittings 2 of them are definitely in zone 2 and not suitable for location
Are they pendants or battens.
If the light fitting is above 2.25 meters from floor level then it will be out of any of the zones tho it should be suitable for the external influences that a bathroom offers.
Reactions: SparkyChick
it was just above my head and im 6ft, i thought all rooms containing showers/baths should have waterproof light fittings, maybe just my last boss being overly fussy and its rubbed off on me
may have to just put all the fittings to c3 as "what is suitable" is a bit vague, my opinion is that rooms with water and electricity the fittings should be of a decent IP rating, maybe im just too fussy but i wouldnt be happy fitting those in a bathroom.
i remember as a kid splashing water onto a lightbulb when it was on, smashed glass everywhere and in the pitch black too..
you need to brush up on your coding IMHO
Some bedtime reading for you!
https://www.----------------------------/mediafile/100404922/Best-Practice-Guide-4-Issue-4.pdf
Do you mean something like this?
  • Funny
im still learning, by no means an expert on the regs lol, still just a 3rd year :D, like learning to drive it is only when you go out on your own that you really learn, the more i read over the regs its definitely a c3 offence.
as a rule of thumb if a room contained a bog it got a waterproof light fitting when doing inspections, at least on the council contracts at my last job
In which case why isn't your boss checking all this?
i mean that the pipes should be earthed internally to the earth terminal inside the boiler itself so no real need for bonding with tags and cable
the light fittings may come down to a matter of opinion over what is "suitable" as i did not measure the height of the lowest point of the pendant from the ground
bathroom light question/boiler earth bonding
elsparko,
elsparko,
