A
A2HGO
Recently moved into a new house (its an old barn conversion not new build). Most rooms have an aerial socket but none have any signal.
It appears the aerial coax comes directly from the aerial, down the roof, wall and into the main living room.
Plugging this cable directly into a TV I get signal and most channels.
Plugging this cable into the wall in the living room, seems to then feed the other sockets across the property...but now I can't plug it into the TV in the living room and splitting it results in very weak signal to all sockets.
Theres an amp in the loft with 8-9 coax cables coming out of it, I assume somehow the aerial cable comes into the living room and then plugging into the wall goes back up to the loft.
Any reason why they didn't take the aerial into the loft from the roof?
Do I need a pre-amp in order to split the cable without loosing signal?
Dropbox - IMG_2625.JPG - https://www.dropbox.com/s/5ltvytvfk9s38y0/IMG_2625.JPG?dl=0
Dropbox - IMG_4070.JPG - https://www.dropbox.com/s/2doxabe63m2aoa6/IMG_4070.JPG?dl=0
