Would you consider a domestic installation as unlikely to need consideration for high integrity earthing unless there is a specific reason (e.g. medical equipment)?
Yes, if a circuit was intended to supply alot of high earth leakage equipment or upon measurement leaked 10mA or more then I would protect that circuit/ split accordingly eg. with type A/B RCD. And high integrity earthing.
But like you mentioned this would most likley be Radials with a seperate earth run as a ring.
I dont think its really necessary to install high integrity earthing in most domestic cases, but it is important to protect with the right type RCD to avoid nuisance tripping, and make sure the RCD would not be effected by the leakage and operate correctly
Where is that bad spelling button that you keep on using on my posts?
Ah well someone else got in first Ant, so damage control has been activated, better luck next time, I'll be waiting!!!!!!!!!!!!!!:tongue::tongue:
  • Funny
Reactions: ruston
  • Disagree
  • Disagree
Yes very, as are the dislike and disagree but you get far to much flak when hitting those two.
Nearly as much as repeating messages, Pedro;)
Reactions: DPG and ipf
I'm not the only one with this problem.
Yep, I have the odd prob, too...…..
Just blame it on the specs.:)
Just delete one?
Reactions: Pete999
Hi Sarah, the chasing is certainly untidy and if the wall had crumbled away I would have plastered around the sockets myself before second fixing. The wire should not have come out of the socket even with it being moved around. The melted socket is more than likely down to what the builder plugged in(to much load). Certificate needs to be issued within 25 days (NICEIC) and should have been registered online.
On the upside they have used MK gear which is generally better quality.
  • Disagree
Reactions: 123 and telectrix
MK gear is crap.
Reactions: 123
An increasingly prevalent opinion.
Could you put some meat on those bones?
In times of old MK stood for quality with robust and long lasting equipment
Its domestic range these days (and for the last 20 years) has stood for Mediocre (crap) Kit
IMO MK stuff is quite well put together; some of their terminal screws aren't so good and leaning mcb’s. But the rests ok, and they look good.
There's a lot else there thats much worse.
There's also a lot else that's much better
What, and how much better; name your enemy of choice, we are all friends here :). Quite like the Click Scholmore range, but still think the MK stuff (talking basic white plastic) looks………………………………………………………...nice!
Reactions: Jim_e_Jib
Been installing plenty MK Aspect top of the range, flat plate on one job. No problems....but still much prefer the Schneider 'Ultimate' (GET) range.....a bit cheaper, better to work with and better looking, for me. Class stuff.
Hate that stuff with a passion.
It looks cr@p too if the plasterer isn't perfect.
Reactions: ruston
I've measured circuits running computers loads of times, never gets close to the 3.5mA that is suggested per device. We've even got one room (not my work, soon to be moved) with 30 computers on the same rcbo, and I can't ever recall being asked to reset the device. (And yes, the rcbo is functional)
I tend to get MK sockets as a) they offer outboard rockers and b) they have two earth terminals. Only other brand I can remember offering two earth terminals (apart from LAP CRAP) is Crabtree. Used to install Schneider when in the housing game and sure they were only single earth terminals.
Maybe....but this ain't your 'run of your mill' rewire..
.. on some jobs the plastering HAS to be perfect......and what is specified is installed.
Love Hager boards, never come across their accessories. Click feels a little flimsy for me to be honest.
Yes , the boards are great . Their light switches have a neutral terminal which is handy if you like it neat.
Click sockets are good , so is the cooker switch /socket, but I tend to agree with on their light switches.
Their cooker duel outlets are superb.
Schneider/GET Ultimate...…
Appearance wise most look similar, even the no brands look near enough the same. Quality wise MK is lacking, it's well over priced pruck.
I use Click.
If I was MK I would forget doing consumer units.
There is no need to seperate earth terminals on a Domestic install. You are right Stuey in what you say but lets not take things to the extreme.
This sounds like regurgitated carp from some college lecturer.
Switching PSUs are a slight problem we are all aware DC equipment has a higher earth leakage but how many does the average house have ?
Do you know how this installation is used by looking at a picture ? This install could be a elderly couple house, not a hackers house with multiple USB sockets and PSUs plugged in.
Led lighting is not usually applicable to either as this on the lighting circuit.
Lets not jump in and insult someones work, leave all this rubbish to the Facebook groups ;)
I Did neither. Don't Jump to conclusions,
It appears that most domestic Electricians don't or won't take this into account .
As I stated in my first ( Other post ) .I have recently returned from Australia after working in Industrial , Commercial and marine. Ring circuits are not even allowed in Australia ( NOT final circuits anyway ) .After reading and catching up with the regs ( 18th) , I came across this regulation and others that state shall and recommended .It appears that these regulations are Ignored. To be called dumb is a ridiculous statement as it's a very valid point . To take a back step the easy answer would have been we don't bother to look at that possibility.
Earth leakage is a growing problem as is the related nuisance tripping of RCDs.
I Did not rubbish anyone's work , I even stated sorry if you took it the wrong way .The trouble with the written word , people can and do misunderstand the point !
Reactions: Charlie_
Advice wanted - unhappy with rewire
Sarah123,
Stuey,
