H
Holden Customs
Sorry I may have worded it wrong before, there is no actual kill switch. The relay acts as the kill switch. The ignitions power flows through it so if it ever switches off then the whole engine control unit goes dead and it shuts down fuel as well. I have tested the function of the relay and just used an alternate power source as the switch instead of the sensor and everything works as it should.What is the kill switch connected to out of interest. Is it to disable the ignition or the fuel pump .
