- Mar 21, 2021
- 170
- 24
- 93
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi,
I have an aico alarm system which was mains powered and interconnected when installed 3 years ago. It's not been maintained and when I took a look recently, a couple of the detectors are missing. Only the ceiling plate is on the ceiling. Also, the interconnect isn't working. When I test any smoke detector, only that beeps and - none of the others.
I need to ensure that they are all still mains powered and restore the interconnection between them. They have a 3 core and earth cable for the interconnect.
I am pretty handy with electrics and own various tools including a fluke 2 pole tester.
I have 8 detectors. Can you please suggest a logical approach for this. Does the indicator on the detectors have any significance?
Look forward to receiving your advice. Thanks in advance.
