- Dec 18, 2011
- 5,379
- 6,732
- 405,788
- United Kingdom
I need to buy an EV tester in order to carry out all the required tests.
I'm just a little unsure about one or 2 things...
1. Is an EV tester the same as an EV test adaptor? These terms seem to be used interchangeably.
2. Does the EV tester actually do the tests or do you plug them into your MFT? I'm sure it's the latter, but I just want to be certain.
3. Are all EV testers compatible with all MFT's or do you have to buy one that works with your particular MFT? I have a megger 1731, could I use the kewtech EV tester for example?
Thanks in advance @Gavin John Hyde , oops, I mean thanks in advance everyone ?
