Discuss Exposed copper wire under the floorboards after rewire in the UK Electrical Forum area at ElectriciansForums.net
Worth noting that even if you post a very good standard of work on this forum its going to get some criticism.
That said, that doesn't look like a very good standard of work at all from any of the photo's so far, it'll be interesting to see what actions, if any, the scheme takes.
A lashed joint like that with all the cores hanging out has never been acceptable , even rough old electricians would have wrapped it in some tape
What makes it worse is the OP hired an 'electrician' to do the re-wire and this is the dogs breakfast they got.
I could understand the mess if they hired a builder or plumber to do the re-wire but not from a trained electrician.
This industry especially the domestic sector has gone to the dogs and the rough work I see on a regular basis done by so called cps sparks is terrifying.
I even saw a bypassed rcd the other day done by a so called cps sparks. This has to be an all time low for the industry.
I have tried reporting these imposters to the scams in the past but nothing ever happens and the homeowner just ends up paying me or someone else to re-do the work.
Shame
Shame
I'm inclined to agree but, no matter what sort of training this 'electrician' undertook, they'll have known full well that such work is unacceptable.
A close up if the bottom of the consumer unit would also be interesting, to see what sort of a gland or grommet they have used - hopefully it is not cables resting on the sharp edge of the metal.
That was also my though. If the exposed joints are typical of the "workmanship" then a lack of proper cable protection/support is not going to surprise me :(
Agreed but even if they are original and now unused cables, I would expect to see them in an enclosure
Of course everybody is assuming that the exposed terminals are part of the rewire and not the original wiring.
Just saying.
Even if by some twist of fate that birds nest joint was the original wiring , Imo any sparks worth their salt during a full rewire should of at very least put it all in a choc box or adaptable box
£2.50 from any wholesalers
Problem solved
is that relic mushroom free without a cable tie and bare cpc's twisted oiutside the box??
I save JBs for the Rolls Royce Jobs , normally I just twist the wires together and sling the whole mess under the floor boards....
Isn't that what every one does ???
I have to say after reading through the thread from the start until the picture of the consumer unit, I was fully expecting to see a BG split load board.
Haha I was going to say the exact same thing, as soon as you see a BG split load board with no SPD on a new consumer unit you know its gunna be rough... Cheapest consumer unit Screwfix sell.
Personally I just don't give customers the choice, I fit Hager, if they want something cheaper they can go with someone else, clearly this is the result.. Worst thing for the OP is I bet they weren't cheap either.. I know as electricians we always moan about other peoples work as we all like to do things our own way etc but I think we can unanimously all agree that is as rough as old boots, how have these people been allowed to continue in the industry, I blame the CPS's, NICEIC should not be suggesting the customer make an official complaint to the company, with such poor workmanship they should be coming out and checking and then chucking that company out of their scheme and banning that person from joining and telling NAPIT about him so he cant join them.. But of course they just want their money..
another small gripe is the internal tails feeding the RCDs. in the wqy. i usually take them out to wire in the circuis, then refit them after. sometimes i even get them in the right order.
Just reading the Toolstation flyer that arrived by post offering "18th edtition" Contactum CUs dual RCD without SPD. Really?
DIY market , it is huge. A few months ago I looked at a job where the retired home owner attempted his own board change purchased on sale from Toolstation but one of his RCDs kept tripping out. He couldn't find the borrowed N on the lighting
1. SPDs are optional,not mandatory.
True, but if not fitted there should be a risk assessment to justify it. Which I doubt happens in most cases.
My gripe is more about the stupid "18th edition" naming. You could argue that "17th amendment 3" makes sense for the metal CU that became a requirement then, but if calling it "18th" then what was added if it is not the SPD?
Absolutely. It just causes more confusion calling them 17th or 18th edition units. Doesn't help anybody. Sparkies don't need it, and the average DIY guy probably going to think his work is 18th compliant because it says so on the box.
This is where a Sharpie is your friend Tel, saves 10 seconds thinking time. 😀
Off topic, but does anyone else sharpie the internal tops of MCB's with the cct details so that you can ident them with the panel off?
I do sometimes number them on the top during an eicr if it's a particularly bad rats nest.
If I'm doing a label print for the outside cover, I normally just do a 2nd label for the bus bar cover inside.
Genuine question, not a challenge.... apart from the expense, does adding a label internally comply with fire retardancy requirements for a type tested unit?
I would say not a problem, as there are already paper labels on the inside of the consumer unit (terminal labels for earth and neutral bars for example).
Strictly speaking I imagine you probably shouldn't add any paper or plastic based labels to the inside of any manufactured product. Not that there would ever be any comeback.
I can only think of issues in really odd cases such as someone sticking a label near mains voltage terminals, and it gets damp and tracks across.
Plenty of 3 phase units have an identical label inside and on the outer cover. Of course they are provided that way by manufacturer so that's a bit different. Just for fun I might try setting fire to a brother label later....
I wouldn't have thought it would provide much fuel for long in a metal unit.
Yeah absolutely. Should be no real world issues.
Mind you, don't use the metallic foil tape 😀
so the legend on the B&H packet is a no-no? wrote smoke, but some AI dipstick turned it to smokes. F£G FFS
I doubt that a label makes much difference compared to all the pvc you add when cables are installed.
I think a pedant would probably say that the cables are already accounted for in a type test by virtue of the various standards and compliances, whereas the added label has no known BS EN standards materials, adhesive, ink...
That probably applies to all the screwdrivers I have left in various panels over the years too.
couple of torches have been lost in the same manor I think.
thankfully they have not caused any spontaneous combustion as far as I know!
The opposite applies too (Confession) - I’ve had a neutral link bar for an Mk split load board in my toolbox for years. I first noticed it after a frantic week and thought ‘someone will phone up and say 50% of things aren’t working’. No one ever did!
Reply to Exposed copper wire under the floorboards after rewire in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Looking for opinions on this guys.... I visited a rewire on a bungalow, classic build, a concrete floor slab with gap above then floorboards ( the...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Had a floorboard up recently following a water leak. While there, thought I would connect in a stair light, which previously was switched...
