- May 11, 2023
- 8
- 2
- 33
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi all,
I’ve had some good advice here in the last week or so which has made me ask a few more questions.
1. Ring main uses the old Red and Black PVC cables, is it okay to add on to a ring main with newer cable ?
2. Is it the norm? to use Wago’s to split a ring main and extend ?
3. My sockets are located in the skirting board, once I‘ve chased the wall out is it deemed safe ( to use the hole in the skirting board as a location to split and store the Waco’s? ( with or without a Wago box)
(The first socket from the CU)
Just to mention I have my 2330, although I don’t work in the trade and if it’s not deemed safe then I am more than happy to get a qualified person in.
