S
sparkymarky123
ok guys i'm an aircraft electrician so i have little knowledge of domestic electrics (honesty check
Info: I have run 20 metres of 6mm swa to my garage from a 13a spur off house ring main. (This is protected at the house c.u by the existing 32a mcb 30a split load mccb for the existing ring)
The swa is terminated in a junction box at the garage to take 2.5mm t&e around the garage. The 2.5mm goes in through the garage wall straight into a double power socket then into a 3 amp switched fcu to run two lights- a PIR flood outside and a 6ft fluorescent tube.
1) does this all sound ok so far? I hope so dont want to buy anything else!!!
2) how would you connect the lights? i have bought loads of 2.5mm t&e as i thought that would be for the lighting but now realise i would have been better with 1mm or 1.5mm. BUGGER! still going to try using the 2.5mm though as i have bought it now.
(N.B i have also put a double gang light switch on the wall- a 2 way one) I have no idea how to wire the lights so that the pir has a permanent live so that it will work all the time and how to wire the flourescent tube so that it is switched............... i've seen about a million ways to wire lights on the net but none yet that cover my installation!
thanks for any help!!!!!!!!!!!!!!
mark
mark
