I
iamelectric
got a job to install a 63amp supply 3 phase commando socket , for a lighting show for an opening night , it was a metre from the D.B so i wired it in 16mm SY cable, i have now been asked to supply am extension cable for it , one male plug one female plug , about 25m long , i was thinking of using 10mm SY for it as its more manageable , but 10mm comes in at 61 amps ccc , is this ok as its an extension?
Personally I'd use H07RNF 16mm cable. 16mm to allow for any high neutral currents from the dimming equipment and to reduce voltage drop.
Why would you think that an extension lead can have a lower ccc than the OCPD protecting it?
well its like plugin a machine in that only has a 1.5 cable into a 32amp circuit
^^^^ what do u mean i have already installed the socket
As in the 63A socket (and plug) of the extension cable you are creating?
In any case a different sort of regulations apply ... BS7909 and regulation 7.3.3 states:
Cables for use outdoors and in general use should be rubber insulated and
sheathed in accordance with BS 7919 (H07RN-F or equivalent), with a
voltage designation of not less than 450/750 V (heavy duty flexible, as
defined in BS 7540-1) and resistant to abrasion and water.
NOTE 2 Thermoplastic cables are not designed for use outdoors. For example,
cables known as ‘arctic blue’, ‘SY’ are thermoplastic and are not suitable for use
outdoors.
what i mean to say is the current demand from any applied load should not exceed the rating of the cable attached to it...
16mm 3 core H07-RNF ... nice n easy :)
a commando plug does not have a fuse in it , i have seen many extensions and machines plugged into 32amp circuits without being fused down
Would you use a 5A extension cable to power a 10A appliance, fed from a standard ringmain? Daz
63amp extension lead
iamelectric,
iamelectric,
