Discuss 63A dno fuse in the UK Electrical Forum area at ElectriciansForums.net
years ago the dno fitted a 63A fuse but over time my needs have grown. is it a case of just getting the dno to fit a bigher fuse or are there other bits involved. meter tails are 25mm and about 0.5m long.
kind regards
As above get the DNO to do a site assessment and see. Very likely they can upgrade you to an 80A fuse, but they must verify first.
Do you have concerns you are using more than the fuse rating ?
his cannabis plants will benefit from 80A. :(:(:(
Reply to 63A dno fuse in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Looks very strange to me. Obviously had a new fuse carrier fitted to it at one point but the two cables on the left go to the meter as normal...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
