Discuss central light fitting in the UK Electrical Forum area at ElectriciansForums.net
cmkjdk
Hi HELP please
I have bought a central light for living room it has 6 bulbs in it , wired in turn on , bulb s flash on / off once and stay off does not throw fuse ?? any advice please
That could be compact fluorescent, halogen, or led. You can get issues if using a dimmer switch with led or fluorescent.
Connections should be checked if this is not the case.
not any of these, old lights in place at moment with 3 bulbs in, work ok
dimmer dimmer dimmer, dimmer dimmer dimmer.
dimmer dimmer.....batman
Reply to central light fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
