Jul 13, 2018
55
16
83
Cheshire
Business Name
Stay Switched On
Hi Guys just a quick question but what the hell do I put in confirmation of earthing conductor size when the earth is the swa
Reactions: Zdb
Refer to the Table Buzz has provided
I've already checked the table but it's not the csa I'm after which option on ecr do I put pass/na/nv etc
Your first post IS referring to cpc size isn't it?
refer to the chart it will give the size equiv to CU
No just the equiv SWA size compared to CU
How can the armour be your earthing conductor. I assume this is a submain and the armour is not the source earthing conductor.
  • Agree
Reactions: Deleted account
please elaborate.. what are you doing ?
  • Agree
Reactions: westward10
have the op gone off the boil ,because if pops on tell me. I will be in the kitchen making a cup of rosy lee . and will grab a couple of biscuits this going to be a long night .;)
I'm filling out an EICR on a landlord supply there is a small consumer unit fed by 25mm 2 cire swa from an isolator which is fed from 25mm tails from a meter with a 16mm earth my question is how can I confirm the conductor size to the consumer unit when it is swa
It is a cpc then.
If your earthing system is TN-C-S then the armour is inadequate to support main protective bonding.
You getting your post count up Buzz
I want to be a forum mentalist like you ian 1981 i have been a bad boy in the past .I have turn over the bed sheet .:)
  • Funny
Reactions: DPG and Ian1981
I have now started to go to church and go to the sort my sins out .
but the devil is still in side me waiting to get out .:D
Cheshire
Business Name
Stay Switched On
Daveh36,
buzzlightyear,
