Discuss confirmation of earthing conductor size in the UK Electrical Forum area at ElectriciansForums.net
I'm filling out an EICR on a landlord supply there is a small consumer unit fed by 25mm 2 cire swa from an isolator which is fed from 25mm tails from a meter with a 16mm earth my question is how can I confirm the conductor size to the consumer unit when it is swa
If your earthing system is TN-C-S then the armour is inadequate to support main protective bonding.
Reply to confirmation of earthing conductor size in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
