Discuss Could I use old telephone wire to run 24VDC for LED lighting use? in the Lighting Forum area at ElectriciansForums.net
Hello,
I am in the middle of installing some 24VDC LED Strip lights in my daughters bedroom and was struggling on how to hide the transformer as I did not want to mount a box on the wall to conceal it or run wires through the wall into her closet. After thinking about this I happen to find the old telephone wire in a box behind her bed. I did a trace on the wire and found it in my basement server room which makes ideal.
My thought was to mount the transformer on the wall in my basement and use 2 of the 4 conductors from the telephone wire that run to her room as the 24VDC supply source to a Shelly RGBW2 which I would conceal in the telephone wire box and run all the LED wiring right into the box. While this sounds simple enough and I am possibly overthinking this I was wondering if there may be a drawback to this? As far as I can tell, the wire gauge is the same as the LED just solid instead of stranded.
Thanks in advance
I thought about that but the Mean Wells power supply has some adjustment on the voltage side albeit that I am not sure if it will be enough to get me to my 24VDC at about 30' from the Shelly RGBW2.... However thanks for the reply as I am leaving nothing to chance. Only want to do this once correctly.
What LEDs are you fitting? What Watts are what?
Reply to Could I use old telephone wire to run 24VDC for LED lighting use? in the Lighting Forum area at ElectriciansForums.net
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
