Discuss Difficult customer- need some advice. in the The Welcome Forum area at ElectriciansForums.net
Got to keep my nose clean or I would take so much pleasure doing this.
I got caught out earlier this year
A landlord needed an EICR for his let property, I carried out the EICR and it failed.
When I sent him the invoice he replied that he wanted me to check it all out and give a cost for the remedial works.
I checked the call recording and he did not say he wanted an EICR- I mentioned the EICR and he neither accepted or declined.
Swift change to my terms and conditions and an updated EICR estimate template which I can send out to people within 5 minutes.
The software adds the correct pages with terms and conditions etc and people can either accept or decline the works.
I have tried the Tradify / Powered now stuff and found Xero better- you can download an estimate template in word, add your own terms and conditions and they appear at the end of EVERY estimate you send.
Reply to Difficult customer- need some advice. in the The Welcome Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
