Discuss DIY enthusiasts and electrical work. in the UK Electrical Forum area at ElectriciansForums.net
If it goes far enough to cover replacing of lights/sockets like for like then B&Q and such will no doubt start offering a fitting service with every such item sold, and probably at surprisingly low cost "Would you like us to schedule an electrician to fit these for you? It's £10 per light including electrical safety testing"... they could easily afford to do that as their in house sparks would be booked up back to back 40 hours a week, akin to a sky/broadband engineers schedule.
That's progress..
It would be if the sockets were fitted properly by a competent electrician, who tested the final circuit to see if it was functioning correctly, and also the RCD if that was fitted.
I've just done 5 years of domestic work. I've seen some right lash up's, where diy's have replaced some standard white plastic to some fancy metal ones, spurred off etc. I had to correctly re-connect a customer Class 1 luminaire, where some handyman (aimed squarely at the over 60's) who decided to use the live & earth instead. Etc etc. And then there's the kitchen fitters and bathroom fitters, who are doing their bit to make things unsafe. :)
you missed out builders.
I'm sure B&Q would be certain that technically things were done correctly, they would have to test the circuit, including the RCD if there is one. My biggest concern is that sloppy, half arsed work will normally test fine, but it will still be sloppy and half arsed. Especially if it were done by a young unambitious spark that has a schedule of fitting 120 light fittings a week and nothing else.
In a way it would be great to have a very affordable short notice service for fitting lights/sockets simply to deter bodgers from having a go themselves, at least everything would be tested that way. I just imagine a spark living that kind of always busy and tedious existence isn't going to be the most careful pair of hands in your home. The same way as most new houses come with wonky switches and sockets.. It's because they guys fitting them are bored out their minds probably.
more likely it's unqualified, inexperienced lads on minimum wage, employed by developers to get the job done on the cheap.
Yep totally agree, not the guys fault entirely, should be checked over by a QS, seen it many times.
I was often asked to fit luminaires for people that they bought from the likes of B&Q etc. I usually charged £30 for a simple install, with just a Zs test & no cert. I often got some side way glances, and no calls back.
With a bit of research, I realise I wasn't charging enough, for example John Lewis offered a fitment service for £69, for the first hour £49 thereafter.
Don't think its boredom with new builds, just price. That said, I've moved into one recently, and its not all bad, except the spider web wiring in the loft.
Another possible reason for bad workmanship in new builds, and I'm sad to say I had a lot of experience of new builds during my House Bashing days, during the building booms of the early 70s, was the use of Labour, possibly 1 skilled Electrician as a lead person with 4 or 5 "Apprentices in the later stages of their tenure as Apprentices".
This would have been all they had ever done, and had in most cases never been offered the chance of doing any Commercial or Industrial type work, solely because the Management found their usefulness on housing developments far to useful to give them any other sort of work experience.
I ran a site like this, on one occasion, I had a Mortgage and a family to feed and clothe, so my concern was their welfare not the Lads on site.
Many of them thought that House bashing was the B all and end all electrical work, and either stuck at it or decided to go it alone and work for themselves, taking the skills, or lack of, with them, to fester on in infinitude.
I'm sure there will be many of us who recognize this sort of thing, it's therefore not surprising we have the sad state of affairs that our trade is in today, bung a few cables in a new build, give up College and carry on with the basic qualifications and the only experience will be housing work.
And most of that work will be priced so low that there will be little or no scope for work ethics, and pride in their work,
I think some might take umbrage at your remarks there Pete. After all not all new builds are the same, and some think domestic work is a noble cause.
I worked in some big commercial & industrial projects in my time, and some of them were just lashed in as well; just purely down to price.
The thing is, with increasing regulation more electrical work will need to be done by a professional, and it will be a lot more of the very basic work.
I know it's par for the course on these boards to gently mock the efforts of the DIYer, but the reality is the majority of the millions of new light fittings and switches sold at retail stores in this country are currently not fitted by a professional. People buy a light fitting, or their new USB wall sockets etc, and they DIY it. And to be fair, the majority of those people will get on fine and not create any sort of dangerous situation. With increasing regulation all that work will for the first time demand a qualified spark.
That's going to create a lot of extra work but I expect it will become a 'price per light/socket swap' battle to be the cheapest. Some sparks will play that game, they will have order books full of cheap, samey work everyday of the week. Not much of a career but it happens, same as satellite dish fitters etc.
You may be right Middy, I was just expressing my thoughts from my experiences from a while back, could be that some of the lash ups you have quoted are caused by, ex house bashers who know no difference, I'm not saying that is the case, but give it a thought, there should be no case for lash ups, it's down to the price and thoughts of people offering ridiculous prices that cause bad workmanship in the first place, brings a phrase to mind but I'm not sure it may raise peoples ire to a new level, pay peanuts and you get Monkeys, rings true, oh dear I could be in trouble here, but I speak my mind.
Reply to DIY enthusiasts and electrical work. in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Why is the word 'competent' being over used to describe what was once just 'qualified electricians' with experience? Is it to promote proving you...
So, I got a level 2-3 electrical installation diploma fresh out of college with no experience especially onsite. I was wondering whether working...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi, I am 17 years old and my main goal was to become an electrician. But I have been hearing from people that becoming a gas safety technician...
