Discuss Electric combi boilers, NSH, electric radiators ???????????? in the UK Electrical Forum area at ElectriciansForums.net
P
pete1721
HI there
i have just brought an investment property, and there is no gas in the village!! what would you reconmend
is my best option for heating and hot water?? its only going to be a small 2 bed property.
i like the look of the electric combi boilers but dont know any1 that has fitted them so not sure if there any good.
i dont really fancy the massive expense of getting oil boiler and tank installed. any advice would be great.
thanks pete
Have wired a few up over the past 3 yrs, they would be the way to go for you. Very efficient and produce heat very quickly. All the ones I've used have been around 12kw. Seems a lot of power at 1st but beleive me they are good, especially for the size of the unit.
are you sure this is a combi? Not aware of an electric combi on the market and 12kw would give p!ss poor hot water performance.
You could consider an LPG gas boiler (bottles and regulator) if you are not so worried about running costs, or an air source heat pump could pay for itself once the domestic RHI is underway providing the property is well insulated and suitable.
*off to try and find an electric combi*
multi-fuel stove with radiators. burn coal, wood, old furniture, matresses, , car tyres, shoes, any old scrap wood out of skips.
and swiftly back to confirm they do exist!
to make it worse I have worked on one before!
They don't operate in the same way as a gas combi does though, they have stored hot water underneath them, more like a y plan in a box.
Fitted an electric boiler in a 2 bed granny annex nearly 2 years ago (heatrae sadia i think) and the customer is very happy with it's performance.It wasn't a standard combi size, was nearly the size of a fridge freezer with water storage capacity (basicaly like an old immersion tank within the caseing) which gave the benefit of being able to use cheap rate electricity.
If i remember right the manufacturer give specific instructions about being on the right energy tariff (economy 10 or somesuch it was called at the time) for maximum saving's.
Far easier to use and control than nightstore heaters and cheaper to run than electric radiators/heaters.
Reply to Electric combi boilers, NSH, electric radiators ???????????? in the UK Electrical Forum area at ElectriciansForums.net
Hi, my wife and I have decided to bite the bullet re the costs of an electric combi boiler in an off-gas grid one bedroom flat where space is so...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Good morning Guys Looking for some advice with regard to a current job. Building company I'm doing work for are installing...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
