I went to a job the other day to replace a security light. When i touched it i got a shock. After isolating the fitting, i removed the cover to have a look at the connections and all were securely in place. There was no water ingress inside the fitting either. I then removed the flex, turned on the power and checked to see if the flex had an earth. It did not. Can anyone think of a reason why i would get a shock? As i said before, all connections were tight and fully into the connector block and i also checked the halogen lamp connections at the lamp holder and they were fine. Any help about this would be great! THANKS
