M
mpatto
Fitting emergency lights in communal areas of a block of 6 domestic flats (20 years old), non-maintained 8w. does the wiring need to be in FP of can i use t&e or low smoke t&e.
Discuss Emergency Lighting Fp?????? in the Lighting Forum area at ElectriciansForums.net
,sustained lighting where 2 or more lamps in same housing,one acts as a non maintained lamp,the other as a normal lamp similar to combined
This is where the confusion lies, whether or not sustained = maintained. I was always taught that sustained used two separate lamps. whereas maintained used the same lamp.
The first lamp is on all the time while the lighting circuit is energized, usually over exit doors. The second lamp comes on when the power is cut to the lighting circuit, a change over switch then energizes the second lamp from a emergency battery source, it can be contained within the unit or it can be supplied via an emergency circuit (pyro or FP200 )
I think BS7671 chapter 56 covers the different levels of delay allowed for different back-up supplies.
Have'nt seen sustained with two lamps in eon's ( I think they were installed on Noah's Ark though! )
Seems to be some confusion here, as guitarist has stated there is maintained, switchable for public lighting etc, and non maintained which only comes on when there is a loss of power. And I think were we are all getting carried away is the method or system which is installed where fire proof cable is used. Most small installation only require self contained EM, and only equire T&E.
Some larger commercial installaion may be designed with a remote UPS running at 110v or 230v. on these systems pyro, fp200 or fp100 singles will be needed to provide power to the em lights. This fitting usually just has a basic relay fitted which drops out to ups on mains failure.
Reply to Emergency Lighting Fp?????? in the Lighting Forum area at ElectriciansForums.net
