Discuss Flex, 5 core. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
need to source some 5 core black flex for outside use.low power LED lights and provision for a water feature. 0.75mm or 1.0mm. H07RN smallest is 1.5mm. need 25m or could go with 50m and put remainder into stock. any ideas?
thanks. have put in to them for a quote.
If you can share the approx price it would be handy, as I can see a use for my own work for around 80m of 5 core and it need only be 0.75mm (or a 5W PIR light and a control switch).
but ifi bought 100m, you'd only have 75left.
Couldn't find rubber, but plenty of black 5 core pvc..
NYY-J ??
Reply to Flex, 5 core. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Hi all, I'd like to replace some MR16 halogen fittings on an exposed wooden beam to new GU10 fittings which I will be fitting led lamps into. The...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi, The house I've moved in to doesn't have an extractor in the main bathroom so I'm looking at placing an inline extractor in the attic directly...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
