Discuss KVA to amps help in the UK Electrical Forum area at ElectriciansForums.net
geordie
Have got a new supply going in and have been told its 300KVA 3 phase now if i have worked it out correct is comes in a 433 amps which going by the size of the places i would expect to be per phase. Which i take it would be fused down to 400 amps by the DNO
Quick ball park sum for it is:-
3PH is Amps = Kva / 0.73
3PH Kva = Amps x 0.73
1PH Phase use 0.25 instead.
is rtrhat 2.5 th successful propportoin of the plasnts thast grow inro maturity>?
oooww.ps. ale is typring. bewweet shut ip. n
That’s based on the mythical 400V whereas a DNO transformer will be 433V and its rated current output will be based on that.
100KVA=133.3333333333333333333333333A
Not that it’ll make any odds, they’ll just bung a fuse in that’s the next size up.
Since when did a DNO transformer work at 433v?
For the last 80+ years.
Measure the voltage at your house. I’ll put money on it not being 230V but nearer 250V.
I assume you’ve not been an electrician for long.
Haha always has to have a dig don't you? What relevance is that. For your info I was a electrician for over 8 years before moving onto bigger and better things. :)
so, bigger and better things than a spark? when yo rulle the world? seig heil?
Go on then, entertain us! What bigger and better things could their possibly be ?????
maybe............
I await atm84’s reply with baited breath.
He’s probably be better off burger flipping, all he has to do is blithely follow the instructions on the pack. He can’t mess the chips up, I know what was done to them before they reach the outlet.
atm84, eight years in the trade and you haven’t yet worked out that 400V is a work of fiction written jointly by the EU and the IET. In the UK it is totally impractical due to the massive installed infrastructure based on 433V.
It takes but a stroke of the pen to deem 400V as the public supply voltage. The engineering side realized it’s impossible and just ignored the directive. A classic case of it’s my bat and ball, I make the rules.
Some of the lads know of my experiments of lowering the voltage on a 80,000KVA system to 400V. It ended in total disaster and I put the voltage back to 433V pronto.
Reply to KVA to amps help in the UK Electrical Forum area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi all, I’m getting confused as to what the DNO are going to be installing as there main supply and as you all may be aware they tend to be a...
4K
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
