s.keech
Hi when filling out a e.i.c. and it asks for maximum demand, is that the size of cut out fuse or does it mean working out all loads on circuits using diversity,shows what 2 yrs at college taught us.
If you want a rough idea (not saying this is the correct way) you can add up all the breaker sizes and times by 0.4.
i.e 2 x 6amp +1 x 16amp + 2 x 32amp add them all up = 92 x 0.4 = 36.8 amps Maximum Demand
I just want to say that 6/10 is nothing to be scoffed at by the way. Rule of thumb says that after getting an average regarding your own score, say you were a respectable 7 after all your pals had agreed... and you want to know the lowest you can go for that is socially acceptable, and wont result in horrific banter for years to come. you take your score, double it, divide by 3, and thats your bottom line. If you chase anything lower than that, then your basically just a massive pig charmer.
Just wanted to throw that out there in case anyone was wondering.
Before any of the lady folk on here get the hump, same rules apply. It's a unisex method of selection.....just sayin
Mine is gas.
Do I need to take account of the ignition & light when working out my max demand?
