B
Blueday
Hi,
I was hoping someone could help me with following question from an old exam paper I found in the house:
Aring final circuit is fed by pvc cablesin steel conduit from a 240 V a.c. supply. The phase conductor develops a fault of negligible impedance to earth at a socket-outlet. The previously tested value of Zs at the socket-outlet was 0.9 ohms. Assume that a conduit joint develops a resistance of 5 ohms due to local corrosion. State the
(i) probable earth fault current
(ii) probable power developed acrross a joint in the conduit
(iii) likely effects of the fault being sustained.
Many thanks in advance.
