shanky887614
Supporter
May 6, 2011
7,962
1,893
7,688
USA
United States of America
Manufacturer / Distributor / Supplier / Inventor - etc
anybody use them.
my jtl training advisor wants me to check phase rotation of motors for portfolio.
i don't see the point. the only motors we use are for fans and vsd driven so you can see what way they spin.
i thought fair enough if there not expensive ill have a look but at £100 ill pass
Essential bit of kit for any Electrician, working on 3phase equipment, look on ebay £10starting, I have an analogue one and digi not very expensive but it does the job.
Reactions: 1 person
anybody use them.
I have one for sale, 65 quid with free delivery, only been used once, still in the box and an ethos.
can i get a pic or model?
yeah no worries, I will pm the details over in the morning with a photo, it is a proper job, not a numties bit of kit.
thanks mike
so, mike. you didn't like the new avatar i picked for you. how about:
or:
Reactions: 1 person
no pleasing some peeople. :6:
So once you’ve checked rotation how are you going connect the motor?
40 years of dealing with motors and I’ve never used a rotation indicator.
Reactions: 2 people
so it spins in the right direction
ill be honest with you guys, i need one more for completing nvq list becauae the idiots give a long list off loads of things you need to do.
usually i connect cross fingers that o dont have to swap a phase over in isolator
You connect the rotation tester to the motor and turn the motor by hand in the desired direction. The analogue needle settles in either the positive or the negative side of the scale. You then rotation test your supply with the other 3 leads and it will also indicate positive or negative. You make sure your supply rotation corresponds with your desired motor direction.
My tester can be a bit vague on very small motors <2HP. Above that size it's always worked well. We use it mostly on large screw compressors where reverse rotation destroys them.
I see the Fluke one I linked above detects the magnetic fields by proximity rather than being connected directly to the windings so they obviously improved them over the years. They're also about a tenth of the price I paid 2 decades ago so having seen this I'm tempted to get one.
**Edit** I'm almost in tearsat how cheap the Amprobe version is :( It's obviously using the older technology because you connect to the motor with leads and not just magnetic proximity like the Fluke. At the price though it's rude not to buy two of them if you ask me. http://za.rs-online.com/web/p/phase-rotation-testers/6655909/
Shanky, see PM.
yeah ive checked pm. we usually connect
l1 to u
l2 to v
l3 to w
but because we dont usually run a supply to our panels we don't know if the rotation will be correct
the direction it spins depends on the phase rotation if i remember what my tutor was telling me, (poles usually 120o apart if 3 poles)
:edit
phase rotation not angle as i was quite rightly picked up on.
getting my terminology mixed up lol
If you're machine isn't rotation critical then you can just test run to visually check direction. If it's a fan and it's difficult to physically see it then obviously with an axial you can check if it's sucking or blowing. If it's a centrif or mixed flow it could move air in the same direction regardless of rotation depending on the blade-set but 98 times out of 100 it will have a lower running current in the correct direction plus it will be quieter in the correct direction.
Reactions: 1 person
l1 to u
l2 to v
l3 to w
the direction it spins depends on the phase angle if i remember what my tutor was telling me, (poles usually 120o apart if 3 poles)
Eh?
What happens if you swap L2 & L3 say?
Eh?
if reverses direction
it gets pushed/pulled by the poles.
if you swaped them then it would be affected by l3 before l2 so spin in the opersit direction.
l1 to u
l2 to v
l3 to w
:edit
What if it's 4 pole ?:laugh3:
Same here....more money making unnecessaries, IMO.
The sensible method is spin the motor before the coupling is fitted.
Get the rotation wrong on some pumps and compressors your going to be changing the unit.
yeah jtl have a long list they want you to do.
if i miss anything ive got to do it in the training centre as a last resorts
That makes no sense, MICC is mineral insulated copper cable, so how can MICV be anything to do with a polymeric sheath?
Due to a hangover from the days of us having our own power station all the 11KV boards were BYR. We used 550V on the plants with the same rotation.
Then two new plants were build which were using this weird 433V. Some genius decided the rotation should be RYB. They were separate from the older plants so it didn’t matter.
Then it came to major alterations to one of the old plants. It was to retain 550V for some parts, 433 for the new stuff. Me being the resident idiot got lumbered with the job. First question, which rotation? Because it was overlapping with old stuff we went for BYR.
Again not really a problem as they were separate entities or so we thought. The plants spread out as they tend to and started to overlap. I got saddled with rebuilding a switchroom with 550V BYR, 433V RYB and 433V BYR. I was going dizzy! To add to the confusion the two 433V feeds could be interconnected.
Don't envy you mate, borrow a fluke T100 off someone and get the unit/task signed off no point spending coin on something that sounds like will never be used again by yourself
oh and take a little time to brush up on your motor theory too
Reactions: 1 person
Sounds like fun Tony, any oh **** moments or did it all turn on ok?
yeah i know i need to brush up, havent used some of the knowledge since i got my level3 cert back in 2012.
shanky887614
Supporter
USA
phase rotation testers
shanky887614,
shanky887614,
