B
balluff1964
hello all.
New to the forum, my work is mostly industrial, could any one recomend either the siemens logo or the
telemec zelio programmable relays, which would be the easiest one to program ?
thanks
Welcome to Electricians Forum | Electrical Advice Forum | An electrical forum for electricians in the UK!
Hi balluff1964 and welcome to electriciansforums.net!
Hi balluff1964 welcome to the forum
The Telemec Zelio relay is quite simple to use and programme
Not used the Siemens one so can't comment on that
Thanks, will prob give the telemec a go.
hi, used both and while the logo can do more and has extra features id chose the zelio every time ( unless i needed the extra features obviously) and programming a zelio is simple
Their both easy to pick up but how are you programming them have you bought the pc software kit with data cable, as this is straight forward where as trying to program on the unit itself via the LCD is a nightmare.
Also for beginners i would suggest using the block form diagram programming and avoid the more complicated to pick-up ladder form.
balluff1964,
Darkwood,
