Discuss Rewiring - Some questions, don't want to get done again... in the UK Electrical Forum area at ElectriciansForums.net
looping light circuits at switches is fine. sometimes even a better solution for adding smart control, and also means less wiring/connections at the actual lights, esp. with some of these fittings designed for only a single cable entry. might also be a good idea to request a 3 core/E cable from switch/es to light/s. then you have a perm. L at the light. again might be required for smart control.
[automerge]1567500850[/automerge]
can't think of The Who without this masterpiece
Not sure I fully understand but it sounds like a good idea. I do like the idea of future proofing things. I really dont want to have walls and ceilings pulled out again for at least 50 year... I will likely be dead by then anyway.
Hi, just to update the poor electrician came today to discuss the rewire... he must hate me as I was asking lots of questions although the Mrs did make him a cuppa and gave him cake... I didn't tell him I was getting help from you lot.
1. He said he will loop at the switch, not the light fitting as it makes it easier to upgrade things later? I know you can loop at the switch and light but is one preferable. I asked how, said he uses Wago terminals in the back box of the light? I nodded like I knew what he was talking about, but is sounds better than the tape the last bloke used.
2. With regards to the external lights (PIR Lantern ones) / smoke alarms he is putting up, said he will use a junction box to tap into lighting circuit? Kind of makes sense, but given its a rewire can't it be done without breaking my brand new circuit?
3. Said the consumer unit is ok, a cheaper one with not much space to add more circuits so suggested not to put smoke alarms on separate circuit as we might run out of space for more useful things later on given that we plan further work. That's annoying... I can see a larger consumer unit being needed later on :(
4. He did say he would prefer to do it after the boiler has been done, as he doesn't trust them to not ruin his work or bugger something up... lol.
Seemed like a good bloke, I will let you know how we get on. Again, very appreciative of people's help. Before, the last problems I would never have thought of asking so many questions but with electricity you can't be too careful.
1, both methods have their merits, looping at the switch makes it easy to upgrade to smart switches later. Wago terminals are generally the preferred method these days.
2. Yes these can be connected in without joint boxes, ask him to do this. I recommend having an isolator somewhere for the external lights so they can be swiftched off if they become faulty.
3. If you need a larger consumer unit for future planned work then tell him that you need this, you are paying the bill so you can have what you want fitted (within the requirements of the regulations etc)
However it is a good sign that he isn't trying to sell a new consumer unit unnecessarily.
4. I agree, plumbers are good at wrecking things.
Great, it did make sense, especially when he said that some of the swanky light fittings don't have alot of space now days and it might be difficult to get them connected up. I thought he was trying to make his life easier when we actually get new light fittings as opposed to the £1.99 screwfix pendants there now.
Ok, so being a little naughty with saying he needs to break circuit. Bad boy lol. The isolator is a good idea, I assume just a switch, not one of those industrial red ones lol. I know the old man's sensor lights got stuck on for about a week once and had no way to switch them off. Plus they were the old style halogon bulbs lol. He was moaning about the cost of electricity and threatened to shoot the bulbs out with an air rifle.
Yeah, he seems like a sound bloke. We had one recently, guy did us, new guy fixed it. I will ask him how much to add a larger one. Though it might have to wait
Nothing naughty about it. Many floods etc. are pre-flexed so will require an adaptable box next to them to connect to the fixed wiring. Nothing wrong with that done properly.
My advice is to leave him to the job unless you want to put him off doing it. And IMO domestic smokes are always better on a lightning circuit than a dedicated circuit regardless of spare capacity in the distribution board.
It's a perfectly acceptable an common method that has been suggested.
From the responses you've given from the persons reactions, I would say they are probably a good choice.
Also, just note, most electricians wont offer any warranty on fittings and items that you yourself are supplying. So if a fitting fails within a couple of weeks randomly through no fault of anyone, expect a charge to come out and fix it.
Cool, I'm fine with him using junction boxes if its the safe thing to do and within the regs. We are only supplying the Lantern PIR light things as the Mrs is so indecisive. Being a bloke, I'd just tell him to get a good one, in black lol.
I don't want to turn into one of those annoying hoovering people that won't leave you alone while you are working, I just want to make sure its done properly and safely.
Its actually a little easier and quicker to loop at the light than at the the switch.
I would go for a 20A double pole switch to isolate external lights (they look like a normal light switch but disconnect both L and N) because then if it develops a neutral fault which trips an RCD you can switch it off and reset the RCD to restore power to the rest of the circuit.
I will ask the chap to fit some double poles, he might have already planned to do it to be fair to him. He does sound like he knows what he is doing. I suppose that's easier than shooting out the lights when they won't switch off for days at a time. ;)
bad idea to shoot lights out. :
1. you can't eat them.
2. as a 12 year old i got copped by the local beat flatfoot for shooting out a streetlight. a clout round the head hurts. these days, it would be an asbo and /or an electronic tag, coupled with the warning " don't do it again". some deterrent?
Reply to Rewiring - Some questions, don't want to get done again... in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
