E
E.E.I
hi can anyone recommend a brand that sells an RGBW ip rated marker light, preferably around 30-40mm looking at collingwood but the smallest they do is 60mm
the light is going to be installed in a shower alcove
Nobody?
Have you looked into fibre optics? I know if a low powered rgbw light source that would do just the job 5W max. Various stainless end fittings to choose from.
Reactions: Admin
Those look ok but I would be wary of quality, all depends on what your after really. If you are installing them In a location which you will never access again once bathroom is completed, I would go with fibre optics. You can get them off the shelf from unlimited light, but more options from universal fibre optics. (Both the same company)
The other thing is they do not offer a pure white led, most make white out of red green and blue which can ben poor, fibre optics offer a bright pure white option.
RGBW Marker lights
Lighting Forum
Thread Tags
E.E.I,
Rocboni,
