Discuss RGBW Marker lights in the Lighting Forum area at ElectriciansForums.net
E.E.I
hi can anyone recommend a brand that sells an RGBW ip rated marker light, preferably around 30-40mm looking at collingwood but the smallest they do is 60mm
the light is going to be installed in a shower alcove
Have you looked into fibre optics? I know if a low powered rgbw light source that would do just the job 5W max. Various stainless end fittings to choose from.
Those look ok but I would be wary of quality, all depends on what your after really. If you are installing them In a location which you will never access again once bathroom is completed, I would go with fibre optics. You can get them off the shelf from unlimited light, but more options from universal fibre optics. (Both the same company)
The other thing is they do not offer a pure white led, most make white out of red green and blue which can ben poor, fibre optics offer a bright pure white option.
Reply to RGBW Marker lights in the Lighting Forum area at ElectriciansForums.net
I want to buy two of the above for my property. I am on a budget. The property can get battered by driving rain, finding an outdoor LED flood...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi there, I'm currently working on a project where I'd like to slowly fade the brightness of a series of high brightness RGBW LEDs. Basically...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I want to install a 10m LED recessed lighting strip in an outdoor room. More often than not it will be used with white/warm lighting, so I've...
