Discuss Shaving socket in the Lighting Forum area at ElectriciansForums.net
shaver sockets are usually fed from the lighting circuit. bear in mind that all circuits in a bathroom need to comply with section 701 of BS7671. esp as regards RCD protection.
Yes planning to do it my self
Then the forum should not advise you any more to be fair. All work needs doing to the requirements of BS7671 including cable design and calculation, testing and certification. Bathroom locations are treated as a special location as the risk for potential harm from shock is increased and as such more stringent requirements are in place. Work may also require legally notifying to the local building control dept.
You should get a local electrician to do this simple and probably cheap job for you.
Reply to Shaving socket in the Lighting Forum area at ElectriciansForums.net
Hi folks. Need some help, wanting to add bathroom mirror with built in shaving port but don't want to chop into wall as I can't replace the tiles...
I'm about to do wiring for a small apartment in Azerbaijan. Mostly I will try to use UK standards - ring mains with ELCBs, everywhere earthed, T&E...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi, I have recently moved in to a house where there is a switch outside the bathroom that controls the power to the shaver socket. Never seen...
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
