T
trev
Overhead lines so 25KV
Discuss Where's it all gone? in the UK Electrical Forum area at ElectriciansForums.net
Haha brilliant! I did suggest energising once we've redone the work just as an extra deterrentLast year a guy got a belt while trying to steal cable from the Metro system (It's like Tyneside's very own railway network). when interviewed he told the boys in blue that he thought they turned it off at night after the last train ran.
Muppet
Muppet
Thanks for above.....I'm about to start a brand new install for a family member as I've said on here before seeking advice etc. i know nothing about these date points etc, but it seems the way to go and like you said provide at least some points in and around the house. Any pointers where to look, how to house it all neatly. There is a central cupboard area which is going to house the under floor heating valves. i was going to install the burglar alarm,cctv equipment in there. Any info advice would be appreciated ThanksIn this case as above and including other ELV cabling. So for instance in this property we are doing everything from mains to alarm, TV points, satellite cabling, CCTV, telephone points, ceiling speakers in dining/living room and interestingly in this house a "central hub" where the sky box, blu ray DVD player and any other source will be accessible in high definition via cat 6 by every t.v in the house. This is what the client wants and it is also worth future proofing like mentioned above.
It's amazing how the cable can add up but with this sort of install you are better off having too much than too little, as cables can easily get damaged and the clients may change their mind on how they want to use the system once installed. It's worth covering yourself in big property's with potential data points just in case a wireless system might not work properly. At least then you can easily install further access point if required. Steel beams and foil backed insulation can increase signal drop in new builds especially.
Reply to Where's it all gone? in the UK Electrical Forum area at ElectriciansForums.net
