Discuss Wiring 2 blue wires, 2 brown, copper one with 1 black wire and 1 white wire in the UK Electrical Forum area at ElectriciansForums.net
Juan R
Hi All,
I have a terminal on the wall with 2 blue wires, 2 brown and a copper one (Photo 1), and I would like to connect a lamp which has 1 black wire and 1 white wire (Photo 2).
How should I connect them to make working the lamp?
Thanks in advance for your help,
Juan
Photo 1
Photo 2
The blue and brown at the bottom of the pic and the bare copper wire is the incoming cable.
The black and the other blue is a dubious (and dangerous) cable to something else, as yet unknown.
Where did your light come from? If sold in the UK its wires should be blue and brown.
Is there a second light or a switch nearby that the blue and brown flex could be running to?
I think the other cable also has blue and brown. Maybe a bit darker though.
Edit: ignore the above, I was looking at the wrong photo.
Hi Brian,
Thanks for the reply.
Yes, the lamp is an IKEA one bought in UK (I live in UK too).
I saw on internet that the IKEA wires colours are: black for live and white for neutral.
There is a switch indeed for this lamp, just below of the lamp. I add a picture below:
Thanks!
Juan
If “photo 2” is the light fitting, those bare connectors should be held in an enclosure, and in no way touch each other.
The wall looks like a regular twin and earth feed, should be some green/ yellow sleeving on the bare earth. No idea where the 2 core flex could be going…. Another light?
Be careful drilling into the wall to fix the light…
`This wiring has a very amateurish appearance to it, so I would advise that you engage the services of a competent electrician.
That 'switch' is a fused connection unit, and would not normally be used as a SP light switch. It would normally be used to 'step down' the fusing on a higher current supply to a lower current one, which may or may not be the case here.
Sparking must be the most frustrating job ever. question - "how much to put a light fitting up" answer "£4000 for a complete rewire", every time I go to a job.
Reply to Wiring 2 blue wires, 2 brown, copper one with 1 black wire and 1 white wire in the UK Electrical Forum area at ElectriciansForums.net
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
