What makes you think that???
because he crimps then solders, in that case it is a waste of solder.
if i crimp a cable they are tight together then solder to hold it together.
much better readings than using a steel through crimp
the solder just holds it together and your not moving it when the solder cools
oh alright , you can have your card early.......
i thought it said Acton. that's cockney.
i'd use a non-insulated butt crimp and cover with a bit of gn/y heat shrink. i'd probably forget to slide the h/s on first and have to cut and re-crimp, thought.
My god how many times I have done that, it's a bit like glancing swa, I cut it and splay it all then realise I've not put the hood on it.
not nearly as many times as i've wired up a flex and lighting click plug to realise i've not slid the domed cover on first....
im a clutz.
im a clutz.
...Know what yer mean...i do it all the time,put me crash-helmet on,and realise i've forgot me polo-neck jumper :conehead:
through crimps are made of copper
Silly plumbers!!!
Forty4,
ayjay,
