Thanks Dave,There is nothing wrong with this as the feed in to the garage is fused at 13A already.
2 RCDs in series makes it very hard for you to test the RCD tripping times when you carry out the essential tests before putting your new work in to use.
The additional MCBs won’t make any improvement as the current protection is correct, however they will have no practical negative effect on the installation.
Yes the armour should be earthed at least at one end, preferably the supply end.
No DP isolation is not normally required.
Thanks Dave,
It took a lot of work to get there so thanks for your clear definitive answer.
If others would have done this rather than go off on tangents as to why I wanted more sockets etc we would've been done a lot sooner and I wouldn't have needed to sound like a bolshy git, which I'm not unless people get up my nose.
Again thanks Dave.
Spoon, thanks.Glad you are now sorted mate.
On the flip side of the coin, if you would have just given the info at the beginning then "we would've been done a lot sooner"
succinctly put by ^^^^^ dave. no further comments required, unless they are funny.
asking a lot for some forum electricians to read an OP properly before replying. esp. if it's more than 2 lines.Spoon, thanks.
To be fair if you read the original post again, the info is there and the questions are there.
Will have to agree to disagree.
Spoon, thanks.
asking a lot for some forum electricians to read an OP properly before replying. esp. if it's more than 2 lines.![]()
No only a few every so often, seems that garage installs queries are off the radarUnusual thread that, don't get many garage supply queries.
No only a few every so often, seems that garage installs queries are off the radar![]()
Too cold to go outside wiring garages.No only a few every so often, seems that garage installs queries are off the radar![]()
Don't Spoon, one of the scams will cotton on and start arranging courses. People will start calling themselves Garage Electricians.Right guys... I've just had a brain wave....
I'm going to start a course where you can become a GI..... No.. not a soldier... but a Garage Installer...
no you're not.i know for a fact that your mam and da were married.and I'm illiterate......
Appreciate any comments?
I didn't take any offence by any of the OP's posts... Text is a rubbish form of communication as you never know how to take then....
I'm just brill, so I took then all happy... Just imagined him skipping through fields with a flower in his mouth while texting away....
Get on with them?Ummphh, he was only asking. If he didn't what would we do with our lives![]()
Where's that sarcasm button gone?Unusual thread that, don't get many garage supply queries.
OP - you closed your thread with this line.
You've had plenty of comments back ......... so don't get arsy when you don't like them or YOU think they are off topic.
Appreciate any comments was a bit of an own goal IMHO
How about Garbage Electricians?But they will be Garage Electricians..... We love all electricians...
I see a reasonable solution here.
Mount a small consumer unit in the house over where the current 13A fused spur sits, feed it with the ring main.
Fit two MCBs, 6A and 20A. Use the existing 1.5mm SWA onto the 6A breaker for a lighting circuits and install another 2.5mm SWA for power. If you really wanted to go the whole hog you could install a 4mm SWA and 32A breaker for the sockets.
What part of the regs does this not meet? I'm always up for learning!Yup, that's how a diyer would do it, they don't understand the regs
You jest, don't you? feed a CU from the RFC, cloud cuckoo land for sure.I see a reasonable solution here.
Common bluudy sense Reg 1.1.1What part of the regs does this not meet? I'm always up for learning!
Show me where in BS7671 does my plan fall short? Like I said, I'm always up for learning.Common bluudy sense Reg 1.1.1
See Appendix 15 BS7671 regarding Ring Final Circuits, with specific reference to SPURSShow me where in BS7671 does my plan fall short? Like I said, I'm always up for learning.
That is a pretty random solution.I see a reasonable solution here.
Mate, depends how much you class as a majority.^^ I would say the majority of the suggestions were helpful , and regs compliant with good practice.
Just because they don't concur with what you hoped people would say doesn't mean they are unhelpful.
