- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- United Kingdom
- Retired Electrician
And wiring some circuits for sockets cabinet lighting etc, it will be on your head if you continue trying to jury rig the existing, bite the bullet and tell them what they need to know, not what they don't want to hear.No code.
You need to get used to delivering information that people don't always want to hear.
Its only 4 circuits so I would be talking to the client about changing to a RCBO board ....
Botch?Change the Consumers Unit to provide more ways for new circuits then. Scare the customer? your job will be to provide the safest installation possible, not a botch just because the CU isn't big enough.
By the time they spent money on an EICR, they'd have a CU installed.[/QUOTE
Its all ideal world stuff though. I agree with everything, apart from the botch comment which was made, but ultimately if after ive done the EICR and made recommendations such as a new consumer unit or wiring a new ring and the customer doesnt want to go ahead with such work what do i do? Surely not walk away from a job where i can still comply to current regs.?If it were my job, I would persude them to have a new RCBO CU, new radial or RFC for kitchen, and new lighting circuit for kitchen as well.
Then they have RFC for rest of house, and two lighting circuits. Just my opinion.
Really? How much do you charge respectively for such work?By the time they spent money on an EICR, they'd have a CU installed.
OK I'll rephrase, what you are intending to do is hardly ideal for a major refurbishment, ask yourself how you would integrate the existing socket circuit in to the existing RFC, when a new kitchen ring or Radial would be more appropriate, perhaps "botch" was a bit harsh, "inapropriateBotch?
I appreciate that dont get me wrong. As stated i agree with everything thats being said but as electricians weve all come across situations where doing the ideal job isnt always practical for a number of reasons. So what then?As I said, I don't do EICR's, but I've seen suggestions of around £200 for such like (EICR's)
It's your job & client, so only you know the booby more with that. Just suggesting a alternative viewpoint.
It appears to be present, did a quick visual check and will check continuity properly when the EICR is carried out.How far away from the kitchen is the existing consumer unit? Is the earthing and bonding up to scratch?
I ap
By the time they spent money on an EICR, they'd have half a CU installed.
Which is part of the reasoning behind the EICR. Once completed i can go back to the customer with my recommendations. Ive perhaps been guilty of looking at the job and trying to provide an installation that is both satisfactory but with minimal costs. As far as im concerned i not only have a duty to provide a safe installation but also to be upfront and honest with them. And i think it would be wrong to turn to them and say you need a new consumer unit, ring main etc etc when i can still provide a safe installation.Of course not, and my 1989 house was built with just one RFC. Is there any scope with your client, to revisit this? If not, you'll have to proceed as is, but in your OP it sounds if they want things done 'properly' ?
Oooopps that should have had a 'half' put in there, before anyone says anything[/QUOT
Oooopps that should have had a 'half' put in there, before anyone says anything![]()
Can you not get some technical help fro the part P, CPS you belong to?I ap
W
One of the proposed changes for the 18th, is limiting planned leakage current (is it 30% or something). Difficult to achieve in the planned kitchen refurb. Some way off yet, but something that should be considered with any install, along with division of installation.
i got shot down on here once for a suggestion made about i think RCD protection on socket outlets and the 18th edition. Correct me if im wrong but is a proposed change that all socket outlets will be RCD protected as opposed to those rated at 20a currently. Anyway i was told you install to the CURRENT edition of the regulations.One of the proposed changes for the 18th, is limiting planned leakage current (is it 30% or something). Difficult to achieve in the planned kitchen refurb. Some way off yet, but something that should be considered with any install, along with division of installation.
Not currently part of any scheme. Any notifiable work i carry out i go through LABC they have me on their register as a competant person.Can you not get some technical help fro the part P, CPS you belong to?
